After I twist off the main part of the negative end tab with needle nose pliers I deal with the the four sharp tig-weld prongs by gently tapping the battery on a tempered glass surface. The result is an uneven but not sharp surface.
As for the tabs on top, I usually leave enough material so that I can double, triple or quadruple fold the tab remnant to make a quasi button. I then tap this end on tempered glass as well until the surface is relatively smooth to the touch. Accordingly, on most lights except those with the smallest diameter recesses for anode contact I can avoid having to use a small magnet to make contact.
