UV LED's for sterilization???
drmaxx
Home of chocolate and chalets
However, I do have a specific application I'd like to experiment with and I need your help.
If you find a good and reasonalbe cheap and reliable solution then you're in for quite a large business.
The WHO acknowledges treatement at the point of use as one of the most important measures for improving health worldwide. Even in developing countries there are substantial concerns about hygenic problems that occur within the water system of a house. E.g. Legionella that cause legionellosis or Legionnaires' disease is quite a concern over here in Europe.
A UV-LED that would disinfect the drinking water at the point of use and would run for a long time and would be big business.
phreeflow
Hey DrMaxx...you hit the nail on the head. That's kind of along the lines I was thinking but the technology is just not ready as far as LED's go. For those of you recommending Steripen...I'll be getting one for personal use but I had an industrial application in mind when first initiating the question. I wanted to add uv led's to supplement something I am working on but have decided to just go with the uv tubes.
In case this wasn't already made clear: No.
Actually it wasn't thoroughly touched upon on this thread and I thank you for the clarification. And you're 100% right, the folks at SSC said they had tried all sorts of different lenses and/or filters but they will not change the frequency.
gillestugan
Nora, Sweden
There is a lot of research going on as a cheap UV-C LED would be perfect for water purification in development countries.
LEDs would make it possible to make a small portable solar cell driven water purifier which needs no maintenance.
drmaxx
Not just in in developement countries. Legionella for example requires that we here have to keep our hot water tanks at home at 60 °C. This is one one hand a potential burn threat e.g. with kids and one the other hand costs a lot of energy. Give us a reliable way to disinfect the tap water and you are in business - I am talking here about most of Europe.
phreeflow
Exactly...and a chance to do something good. It's unfortunate that one of the leading causes of death in many developing nations is poor water. It's literally like drinking poison.
travelinman
Western Canada
Not to be a nit picker here, but UV light doesn't actually kill bacteria, it only inhibits it's ability to multiply, thereby stopping it's ability to reproduce. Sort of a miniature vasectomy. :eek:oo: That's good enough however, because a few bacteria won't hurt you, it's only when all the offspring start having offspring etc. etc. that you get harmed.
At least that's what I learned in biology many many years ago.
drmaxx
This is only partly correct. UV light damages the DNA - very unspecific. Some of this damage inhibits important life functions, some of them inhibits growth and multiplying. The key is, that the UV-dose is high enough to damage enough DNA to overload the internal repair mechanism. And this is equal to being dead. Otherwise the microbes are only harmed and require some time to repair themselves. After that they are ready to do their thing again. This is one of the reasons why UV-disinfection has a bad rep in water supply. If you don't do it correctly then you don't really disinfect. Doing it correctly is not an easy thing to do (Computational Fluid Dynamics - anybody?:D).
Rexlion
Tulsa
I'm sorry, it just doesn't work that way. Stop shining that UV LED into your pants, and get a real vasectomy like the rest of us... :crackup:
PhotonWrangler
In a handbasket
It's not an LED, but I just stumbled across a UVC germicidal bulb at Target today. It's in the hardware section by the air purifiers. I bought one to experiment with.
Near as I can find out it's a 3 watt 10v bulb that's intended to work with a ballast in it's host device, a small UV air purifier that plugs into a light socket. The linked page shows a photo of the bulb also.
This lamp is very reminiscent of the old OZ-4 ozone bulb, aka the G-E G4S11, with an incandescent filament and a tiny drop of mercury visible inside the clear quartz envelope. They're commonly used in water purifiers and tootbrush sanitizers as well as air purifiers. Many years ago they used to use the OZ-4 bulbs in commercial restroom hand dryers.
At any rate I'm not sure what I'll use it for yet, but i'll think of something. :huh:
batmanacw
Andover, Ohio
Why not just use the Steripen to begin with?
Steripens are a great way to get sick. They only work in water. If you dip your drinking vessel into the contaminated water source, then use the steripen, what is going to purify the germs you got on the outside and top of the container? You will just recontaminate trying to pour across the top of the container to put it into another container to drink it.
The military tabs tell you to loosen the lid and shake the canteen to get antiseptic water onto the threads. The steripen purified water is not antiseptic so it would not kill anything by itself. The chemicals in the military tabs do actively kill bugs.
Also, sterilized crap is still crap. The solids in the water actually will protect germs inside the solids. Light can't get to it so it lives through the treatment and goes into your belly.
Use a real water filter.
