I'm looking to build a low-power water purification device using UVC light. Some of the most common products currently available are the SteriPEN, Camelbak All Clear, and UV AquaStar. Although I was looking to accomplish this with LEDs, other forum posts here have indicated the diodes that produce the desired wavelength (around 265 nm) are not at all cost effective.
The other products use small fluorescent tubes which produce the correct wavelength as well as visible blue light. Are these small lamps available on the market (ebay or from suppliers)? My searches have only revealed larger lamps which are designed for air purification.
Thanks in advance!
Thanks in advance!
