I am having problems using my XPL HI Patina head on a Black HA body. Occasionally(maybe 1 out of 30-40 times) when I click to change modes, nothing happens. When I try it immediately again, it works. When I use the Patina head w/ Patina body or Black HA head w/ Black HA body, I don't have problems. I noticed that there is a slight gap between the Black head and Black body but almost none for Patina head and Black body. I'm wondering if the problem is because Patina head doesn't totally screw down on the Black body.
Sorry for the difficulty. It could the spacing but it may also be tightness.
BOSS has a dedicated negative contact surface around the spring. This operates when the body is fully tight. Uncoated bodies also have a second path through the threads, that works when threads are clean. Black bodies have coated threads, providing lock out function by preventing the second path, leaving only the primary path. So the first thing to check when it doesnt fire up is that the body is tight against the head.
If that doesn't help there may be another issue. Please let know and we can try more steps.
Will there be a polished Ti version release of BOSS?
We have no plans for it but have also not rulled it out.
What is:
481 service PIN added: on/off the standby locator?
v5 is platform that includes power switch operation (BOSS) and electronic switch operation (fl33, hds). 481 is specific to E switches and is not appliable to clicky switches, including BOSS.
Purchased a ti frosted 70. Running 2x 18350 IMR 700 mAh. Went bright poof and out. Is that too much battery? What battery should I use?
Its possible the cell died under load and wont work in lower draw appications. its also possible the cell is alive, just unable to pass the tests v5 performs every turn on so ensure cells arent over taxed. Every BOSS is hand tested before shipping, let me know if new/other cells dont improve operation!
Note to self... find new source for 18350s. Any update on the AW factory situation?
Still down. I may start making OR batteries.
