fenix store
- Joined
- Feb 27, 2015
- Messages
- 1,563
The Fenix FD65 focusable LED Flashlight is fitted with three Cree XHP35 HI neutral white LED's. It also includes an efficient TIR optical lens that emits a max output of 3800 lumens and has a beam distance of 1,345 feet/410 meters. Rotating the focusing ring on the Fenix FD65 moves the head forward and backward resulting in changing between the spot- and floodlight. Simple two button operation - click the "H" switch to High output and increase the brightness and then click the "L" switch to activate the Low output and decrease the brightness. It is normally powered by four 18650 Li-ion rechargeable batteries. You are able to use just two 18650 batteries in case of emergency. With an IP68 rated protection, momentary on strobe and SOS function, the Fenix FD65 is the perfect flashlight for going caving, outdoor photography, searching and rescuing.
