Sold/Expired Wide/Deep 2x18650 M*g C Tail cap
Greenbean
WNC
45.00 PayPal sent for:
1 W/D tail cap #89 $24.00
2 X 100 mm pvc spacers 14.00
Shippin for three items 7.00
Total $45.00
CPF handle: Greenbean
Bullet Bob
Got the cap. works perfectly. I built an ROP 2 C cell light that had original AW- C batteries that eventually went bad with no replacements and the light has been out of commission. This cap with 2 18650s fixed the problem and now I have my light back.
fivemega
California
Hey FM do these accommodate 26650's also or not?
Each "C" cell has diameter of about 25.5mm and 50mm long while 26650 has diameter of 26.5mm and 69.5mm long.
Adding some extension tube may componsate the extra length but machining and enlarging inside diameter will destroy the extension tail threads.
In order to accomodate pair of 26650 cells, you need 3C M*g and bored out to proper size.
Greenbean
WNC
$36.00 :paypal: for:
1 W/D tail cap #91 $24
100mm PVC pipe $7 each
Shipping $5
Total $36.00
Greenbean
WNC
This might help,
My 2-C with 2x3500 18650 KeepPower cells, before the install of the cap. The marks that you see in the last pic that look like damage to the flashlight are reflections due to my poor lighting.
You can pull the spring out of the cap if needed and adjust length or tension but it was perfect for me.
Greenbean
WNC
$37.00 :paypal: for:
1 W/D tail cap #92 $24
140mm PVC pipe $8 each
Shipping $5
Total $37.00
Bullet Bob
Ill take 94
Paypal sent also included is a battery tube for 2- 18650s in the c cell.
Bullet Bob
Got the tail cap but the tube you sent is not the tube for 2 18650 batts. its too big and wont fit inside the tail cap. I need the right tube.
