Sold/Expired WITHDRAWN FINAL PRICE DROPS-Malkoff MDC Tac w/ 3.0 V batteries (SOLD), Wowtac A6, Panasonic 18500 batteries
msr0407
Shipping Included. CONUS only. Paypal Goods and Services only. No additional fees.
First "I'll take it" wins opportunity to buy. I will confirm winner and send PM with email address for Paypal. Please contact me with any questions. Sorry no apo's.
1. Malkoff MDC TAC. LNIB. $99. NOW $79. SOLD.
Including a pair of Keeppower 3.0V USB-rechargeable batteries. Only a few cycles on these. Also including MDC Bodyguard grip ring.
2. Prometheus titanium clip. LNIB. $20. SOLD
This is the clip at the link below and only works with Malkoff and Surefire unless it's modified.
3. 4 Panasonic 18500 batteries. $24. NOW $16.
Only a few cycles on these. I have two other kinds of 18500s I am using and these are just sitting. Unprotected flat tops.
4. Wowtac A6. Almost perfect condition. $22. NOW $16.
Has been sitting in a drawer. Tiny piece of missing ano. This comes with a Wowtac USB-rechargeable 18650. Only a few cycles.
turbodog
central time
Heads up to the malkoff buyer...
Great light. Please note for 3.2 max voltage... so be sure to use the included cells, primaries, or equivalent.
ilikeguns40
Western PA
Enlarging the hole on that clip is a very tedious process in order not to snap the clip while using a dremel. Do yourself a favor and use a cup of water to dip the clip in every so often after doing a bit of grinding. You don't want that titanium getting hot. It will snap. I used knipex flat jaw pliers to hold the clip sturdy and a wooden table to pin the clip against. Good luck.
jon_slider
"ill take it"
Im not the seller, but will be glad to help you with any questions about installing the clip.
I also have the 2mm O ring you will need between the lens and the reflector. (I had to buy 40 of them to meet minimum order). PM me your address and I will mail you a couple... free, on the house ;-)
turbodog
central time
Im good with that.. Ill take it
Take a dowel small enough to hole in a drill chuck (drill press even better), cut a slot long ways through it, insert sandpaper, turn drill on, hold clip while sandpaper gently and evenly enlarges hole.
A fan is a GOOD idea to help with heat a dust.
