XP-G2 Direct Drive off 1xCR123 or 2xAA?
RobertMM
Las Piñas, Philippines
Hi all.
I managed to source a few XP-G2 on copper sinkpads for a mod, and have some left over.
Would these work fine on a fresh CR123A direct drive, with absolutely nothing to control current or voltage?
Datasheet says 2.8-3.1volts.
Any idea what kind of current the LED may see with this setup? I'm curious with runtime as well.
What I'm planning is to build a moderate/low power dropin to use in a G2 with a dummy CR123. Or maybe two AAs in a G3.
Illum
Central Florida, USA
Works just fine, current pretty much limits itself because the battery voltage is way under the spec voltage at say... 700mA, which will require about 3.8V. Put a fuse in between your LED and your CR123A, so that if your LED does fail short [unlikely unless someone forgot heatsinking] your CR123A will not overheat.
petrochemicals
U.K.
You can, but as has already been stateddue to a current causing the battery voltage to drop, if you start with two good 1.5v cells fully charged, they may start off at 2.8v and go down from there, 2.8 I where the xpg stops working. 1.5v 3aaa cells do give a good output not too much current without a resistor, at about 450ma if i remember correctly, its why head torches use that configuration most often, as you do not have to regulate the voltage or current by a great deal leading to great efficiency. Aa will drive more current through for a while, but not lots more, and once they get past 2.8 v the lights go out anyway.
