Zebralight Hard Hat/Hat Mounting Solutions *NOW WITH SOLUTION PICTURES*
Sphinxxx
Re: Zebralight Hard Hat/Hat Mounting Solutions
For my bike mount i decided to use double-sided tape and stick the silicon mount to the face plate of my stem, then zip tie it on with an X around the clamping area. Its pretty solid because my face plate is flat-ish. Thicker foam tape would be nice but i don't have any. Thanks for inspiring me to finally make a mount, i had put that off for a long time and it took all of 4 minutes. Now just waiting for my H600Fw MK3!!!!!!!! (i was using a zebralight headband for a nitecore HC3. Hopefully the same silicon mount)
bykfixer
Dust in the Wind
I used a telephone repairman shaped (called Bell after Bell telephone) for a summer of night work.
Until acquiring a Coast and fastening it to a conventional hard hat using supplied clips I found that little $6 Energizer stayed fastened to the Bell shaped one using trash bag wires and industrial strength velco pieces.
Later a ziptie replaced the wire.
But the wire makes it removable much easier.
Occasionally folks will ask "what's that fuzzy stuff on your hard hat?" as it no longer has the light attached. I used the fuzzy side on the helmet.
