Check post 36.
Got it, thanks! Wonder how that compares to a SC52 running on a 14500.
Check post 36.
Just to clarify, that was someone else's result, referenced by WalkIntoTheNight. But I will give it a try and see what I get.Yes, and selfbuilt is not the only one to find that result. Pulling six amps out of a humble AA battery is not a recipe for extended runtime.
Based on my SC52 14500 run (re-posted below), the light step-down somewhere between 30 and 60 secs after activation. That would be an awful lot of re-starting, which I don't plan to try.Got it, thanks! Wonder how that compares to a SC52 running on a 14500.
Yes, that's right. H1 is always set to the 525 lm level, but H2 can set to anything you like (115, 200, or 325 lms). It remembers what you picked. So if you want the light to come in in 115, just set H2 that way and turn the light off (it will re-activate in 115). Double-click always brings you the 525lm H1 - there is no way to change that output.Question for the crowd. Can the hi memory be set to the 115 lumen...and double click to 500?
Yes, set H2 to 250lm, and H1 will still be 525lm on double-click.Great! That's how I think I would like to set it up. And is middle mode the same...program for 20ish lumens...double click gets you 50ish? Just looking to set it up tilted towards longer run times...
As you can see, there is no evidence of the PID being engaged at any point. The eventual step-down to lower levels occurred as normal. Note that I got just under ~25 mins on my Eneloop Pro before the light dropped to the lower levels (and again, that's with only a few seconds for each step-down).
From this, I can only assume that the standard uncalibrated PID is set to a temperature level that the SC5 never reaches, even on repeated restarts. That said, I can tell you the button area was getting quite hot near the end of all those re-starts. Using an infrared thermometer, I clocked surface temperatures at the base of the head as high as the low 70 degree C range shortly before output reached the typical H2 level.
I just checked my SC62, and surface temp on that light (uncooled) with multiple re-starts stayed in the low 60 degree C range. But you could see the effect of the PID kicking in immediately to drop output (which meant I had to keep switching for H2 and back to H1 very frequently to try and keep the temp/output up).
Excellent results, thank you. I'm concluding that there is no PID on the SC5, or at least no PID that ever activates at the temperature levels it should.
Yes, I agree on both points. Zebralight does not advertise PID on this model. But I know from my discussion with them that all their new lights - including specifically the SC5 - come with the same standard circuit features (e.g., 384 sub-levels, temperature sensors, etc.) required for the PID thermal regulation. However, the PID parameters in each light have to be individually set (i.e., calibrated), which they have not done on the SC5, opting instead for the simpler step-down on Hi.I'm sure they would have listed PID in the specs and the spreadsheet if it had that feature.
EDIT: Just checked, and surface temps with the infrared thermometer stay below low 50 degree C range the whole time when running on max without restarts (and uncooled).
I ran it for 10 mins at H2 325lm, then turned it up to H1 525lm, and measured temp when it dropped back down to 325lm 3mins later - at that point, it was still under 45 degrees C surface temp. The temp slowly rises over the course of the extended run at 325lm. By ~40 mins into the run (which is shortly before when I expect step-down due to battery exhaustion to occur), the temperature is at its highest point, and was still <53 degrees C.What does it reach at the H2 325 lumen setting? And, if you then turn it up to H1, what does it reach by the end of the 3 minutes?
I suppose if you were to jump to H1 after ~35 mins on H2, you may be able to get temps up a little bit further - but I doubt much higher than the PID level of ~60 C surface temp that I saw on the SC600-II.
Ok, I've done the repeated restarting
I'm Jones'in for this light now.
Note that I only allowed the light to step down for a few seconds before re-starting in max every 3 mins. The standard sample/plotting rate for the graphs above is once every 30 secs, so it makes for wide looking dips - but that's just an artifact of the standard graphing template I developed.
As you can see, there is no evidence of a PID being engaged at any point. The eventual step-down to lower levels occurred as normal. Note that I got just under ~25 mins on my Eneloop Pro before the light dropped to the lower levels
I wonder what the voltage plot would look like? To me the gradual drop in ropv matches that of a NiMH discharge plot. It seems the voltage of the battery plays a significant part to the output. Would mean that the elite 2000 would maintain a higher voltage, but net effect would not be noticed
Sorry, that one "4" was a hold-over from an old review. As stated everywhere else, it are only 2 flashing modes on this light. The frequencies are given on the two oscilloscope traces.The manufacturer info you show says "Beacon Strobe" but doesn't detail all types/levels. You say 4 blinking modes but only mention 2 - fast and slow strobe. Does it really have a true beacon, and if so, what rate(s)?
Yes, the circuit seems to have trouble knowing what to make of the lower voltage L91 energizer lithium. Basically, with a fresh cell at least, you lose H1, and have a delay before the light will provide the highest H2A (i.e., it seems to come on in H2B instead of H1, then eventually jumps up to H2A).The plot of the higher-voltage Energizer lithium primary looks like it performs worse than on an Eneloop, though that may be because the Energizer can't deliver the necessary current.
