markr6
- Joined
- Jul 16, 2012
- Messages
- 9,258
What's the candella rating?
I have no idea; ZL never supplies this. And I don't recall anyone doing any official tests either. A very, very out of the blue guess by me would be 16,000.
Thanks. Found it. He measured 18300cd. Very impressive if accurate.mhanlen, or is it mhalen made a video review on YouTube, which includes a CD measurement.
What is current consumption on fresh cell on highest mode? I winder which cell will be most effective for that light.
Thanks, Mike
What are you peeps using for a holster?
I recently ordered a SC600w Mk III standard version. After that asked myself if I should have got the HI instead. When I search for information the most results are regarding HI version. According to technical specification HI has 8deg hotspot compared to 10deg for the standard version. This should mean ~56% more candela for the HI version, which I think is not a dramatic difference in practise. Or? Anyone who have compared them side by side?
Thanks for the replies and the video!
Yes, the HI version has noticeably more intense hotspot in the video, but I think the regular version is better for allround use. Anyway my regular version is already shipped and I am sure I will be pleased with it. I think the beam profile will be similar as the beam of SC5w, just much brighter/much better runtime for similar brightness level. If I then feel that I want the same light with better throw I can order the HI later and keep both.
I often feel that some lights sort of fall in the region of not being good for general use, flooding, or spotting. For example, I have an old eagletac, the P100A2 with xpe. It has the beam profile of a thrower with a small hotspot and wide and dim spill. However, it doesn't have enough power to really throw well for my uses, and its beam profile makes it unsuitable for me for close up or even general applications. It doesn't get used these days.
For me the HI is somewhat like that. It sacrifices the nice wide general beam of the regular version for one that doesn't really throw well enough.
I find the type of light you're describing to often be quite good hiking lights. You don't really need a heavy thrower, you need some light by your feet, and some throw for further ahead, to scan the path you're taking a while further. Definitively agree though, lights perfect for that application are rarely optimal for close range, and they're not heavy throwers.
Amusing enough that I though I should comment; I ordered the HI specifically hoping that it is such a light.
I feel that if one needs more throw (more than that from a general beam [under 10k CD], but not as extreme as from a dedicated thrower) there are better alternatives than the HI anyways.
A key feature virtually all Zebralights share is their compact pocketable size. An SC600 with a double-size head wouldn't be compact or pocketable.Yes, and actually I feel that it's a bit exaggerated to call it a pocket thrower. It will have some decent throw due to the raw output but it is not a thrower anyway by definition. The runtime will be very short at the highest level and it will very soon be hot, also the brightness will step down. Since a while I have dreamed about a dedicated Zebralight thrower. Why not a SC600 option with twice as large reflector? Then it should be a true thrower!
The one flashlight I still crave is a thrower small enough to put in my pocket but with some spill. I Don't like the pinpoint aspheric square beam with no spill at all. A modern LX2 type light could do the job but Surefire won't build one for me. A 1+ inch head is too wide for me to comfortably pocket carry. Others are too heavy to pocket carry.
