OK - post #1!
I've read through, searched and such, still left with questions that might be common for 1999 Durango, US.
I've gotten the 9007 Philips Extreme Vision, still to try after some fender repairs (deer).
Headlamp assemblys are by Wagner for Chrysler.
One unit is pretty rough, probably gonna' have to spend some $ anyway.
1. Is there another spec. lamp assembly I should search for (Europe or other)?
2. If not, the lamp I have seems to be capable of disassembly - the clear will 'unclip' from the reflector - bad idea?
3. Earlier polish/seal kit link breaks for me, is there an update?
I have the decorative fog lamps - 899s from the factory.
4. Is there an assembly that would use the same size/position/mount? (These are about 3.5 inches, with lateral 1/4 pins at 3/9 o'clock and a vertical spring/screw behind and inside from the 9.)
That's all!
THX
That's all!
THX
