hbk_rey
- Joined
- Nov 2, 2014
- Messages
- 503
KS took really a long time to approve the project, click here to view the page.
Detailed Specs:
Operation:
Detailed Specs:
- Material: Solid Titanium (Ti-6Al-4V, Grade 5)
- LED: 4000k Nichia 219C High CRI
- Compatible cells: AA or 14500
- Finish: Bead blast
- Dimensions: 97x21mm (3.8x0.8in)
- Weight (without battery): 65g (2.3oz)
- Maximum output: 470 lumens
- Minimum output: 0.2 lumens
- Reverse polarity protection
- Low Voltage Protection to prevent damage to Li-Ion cell's
- Active temperature control, to prevent damage to the LED/Driver
- Anti-Reflective (AR) coated lens
- Aluminium Orange Peel reflector
- Reverse-clicky switch
- Ability to tablestand
- Improved pocket clip
- Spare O-Rings
- 10 tritium slots (installed tritium vials are an additional option)
Operation:
- Fully click to turn on, followed by half-press (tap) to change modes. Fully click again to turn off.
- Starts at moonlight (0.2 lumens) by default
- Memory can be switched on or off by giving the button 8 quick taps.
