HKJ
[size=+3]PKCell ICR10440 350mAh (Blue)[/size]
Official specifications:
AAA sized LiIon cells, how good is this brand?
Up to 0.5A the cell works fine, at 1A it has lost some capacity (Sorry, only curve for one cell) and it cannot do anything at 2A
[size=+3]Conclusion[/size]
The performance of this cell is not very impressive, but that is the same for most 10440 cell. The capacity is always around 300mAh and some can deliver more current than other, this one here is not a high current cell!
[size=+3]Notes and links[/size]
How is the test done and how to read the charts
How is a protected LiIon battery constructed
More about button top and flat top batteries
Comparison to other LiIon batteries
- Brand: PKCELL
- Model Number:10440 3.7V Lithium Li-ion Rechargeable Battery
- Type: Li-Ion
- Nominal Voltage: 3.7V
- Size: 10440
- Nominal Capacity: 350mah
- Model: icr10440 350
- Dimension: 10.2mm*44.02mm
- Nominal capacity: 350mAh(NOT HIGH DRAIN)
- Nominal voltage: 3.7V
- Shape: cylinder
- Color: blue
- Top: Flat top
- Usage: e-cigarette
- Weight: 15g
