HKJ
[size=+3]PKCell AAA 850mA (Green-silver)[/size]
Official specifications:
Maximum temperature raise at different discharge currents: 1A:+2,2°C, 2A:+4,9°C, 3A:+7,8°C, 5A:+12,3°C
Medium capacity AAA batteries from PKCell
Discharge curves looks fine for NiMH with 850mAh capacity. I could have wished for better tracking between the cell, but it is not a problem.
[size=+3]Conclusion[/size]
These cells looks fairly good.
[size=+3]Notes and links[/size]
How is the test done and how to read the charts
Compare to other AA/AAA batteries: Alkaline/NiMH/Lithium
- Model: AAA
- Dimension (max): Diameter:10.5(mm) Height:44.5(mm)
- Capacity: 850(mAH)
- Norminal Voltage: 1.2(V)
- Standard Charge Current: 85(mA) Time:15(H)
- Rapid Charge Current: 255(mA) Time:4(H)
- Reference Weight: 13.5g/Pcs
- Ready to Use NiMh Rechargeable Battery AAA/850mAh/4Pcs/Blister
