gearvita
- Joined
- May 17, 2018
- Messages
- 129
Lumintop C01 bicycle light is a versatile rechargeable bicycle headlight, which designed for urban cycling commuting. By adopting the anti-glare multi-faceted reflector, it produces a equal ray, takes care of near and distance illuminations. At the same time, it prevents dazzle to the on coming people and vehicles. Utilizes Cree XP-G3 LED with neutral white color, it has better penetrability, even in rainy and foggy weathers. Three general output levels plus Strobe, SOS, and Beacon with a max output of 400 lumens, it meets the commuting and daily lighting demands. The built-in 1,400mAh high-capacity lithium polymer battery provides a maximum runtime of up to 10.5 hours which meets long-distance cycling requirements. Micro USB direct charging function allows you to charge the light at any time to ensure a sufficient power of your ride. Charging indicator, low-power warning, quick-release structure, IPX-8 waterproof design etc., C01 is your reliable partner in daily commuting, road riding, or in daily use.
Main Parameters:
Light Source: CREE XP-G3 LED
Switch Mode: Low / Medium / High / Strobe / SOS / Beacon
Max Lumen: 450
Lighting Distance : 100 - 200m
Voltage Regulator Support: 5 - 8 files
Body Material: ABS
Battery Type: Li-polymer battery
Waterproof: IP68
Brightness Levels and Runtime:
High: 400 Lumens ( 1h 45min )
Med: 225 Lumens ( 3h 30min )
Low: 75 Lumens ( 10h 30min )
Strobe / SOS / Beacon: 400 Lumens
Product Features:
● Utilizes Cree XP-G3 neutral white LED with better color rendering and a 50,000 hours lifespan.
● Six output levels with Low, Medium, High, Strobe, SOS and Beacon, max 400 lumens.
● Built-in 3.7V/1400mAh Li-polymer battery, provides a 10.5 hours max runtime.
● Micro USB rechargeable with charging indicator.
● Featuring low power indicator and intelligent output downshift function.
● Tapered surface reflector designed with German standard, reduce the hazard of glare to oncoming people.
● Detachable and adjustable bike mount, fit for 19-33mm diameter bicycle handlebar.
● 360-degree rotatable on the mount allows easily to adjust the shooting direction.
● One switch for fast and easy operation.
● Versatile to serve as a bicycle light and handheld flashlight.
● Made of high-intensity ABS materials, solid and lightweight.
● IP68 rated protection, 1.5 meters impact resistance.
Is your bicycle still missing a front light? Let Lumintop C01 illuminates your ride. You can get it from GearVita: https://gearvita.com/lumintop-c01-bicycle-front-light-400-lumens.html
Related products:
https://gearvita.com/fenix-bc30-led-bike-light-1800lm.html
https://gearvita.com/nitecore-br35-rechargeable-bike-light-dual-distance-beam-1800-lumens.html
Main Parameters:
Max Lumen: 450
Body Material: ABS
Waterproof: IP68
Product Features:
Related products:
