A2 LED Aviator mod report
hamhanded
PNW
I haven't been able to find any pictures of the inside of an A2L head anywhere. So I took the $120-$200 plunge (depending on luck, the supply of used A2Ls on Ebay, when you choose to pick one up, and how good your soldering hand is).
The goal was to replace the secondaries with 3mm 95CRI 2800K warm whites. I considered replacing the main LED, but I didn't have any MCPCBs that would get the emitter at the correct height to be flush with the base of the reflector, which sits on the topmost black plastic ring of the Luxeon. This also seems to be a common problem with modding lights like the U2 Ultra.
My method for softening circa-2000 Surefire glue is to boil a shallow pool of water in in a pot, remove the pot from heat, and drop the head lens-down in the water making sure the level stays below the base. Let it sit there for about a minute before working on it. This helps get both of the threads free.
I opted for a red LED host since the secondary drive current would be lower than that of a white host, and new white LEDs are more efficient than those from 2008. I didn't want them to be blazing bright or overdriven. The downside is that the main beam is driven lighter as well, so it's about ~10 lumens dimmer than the A2L-WH from what I understand. I'm happy with the brightness that resulted. Consider it saved battery life.
It comes apart in 3 sections: lens, driver, and retaining base ring, all unscrewing using that heating method and wrenching with strap wrenches.
With the base ring off, I found a black round aluminum heatsink which is held onto the driver by only the main LED lead wires. Unsoldering them and the sleeve slides up and off. Don't rotate the aluminum heatsink, or you risk breaking solder joints on the main wires.
From there, desolder using a steady hand and patience. Some tips:
- confirm the polarity before setting the height down-- for some reason, I found the original LED anvil polarity was reversed
- solder the leads closer to the inside of the PCB to set the height of the LEDs first, since the outer one is easier to work around
- trim your leads a bit long, then use flush cutters to make them flush after the fact
- have extra 3mm LEDs for when you drop one or more into another dimension
I opted not to sand these like I did the 5mm on my incandescent A2, since the smaller LEDs didn't have as much tint banding. So they have a bit more of a spot shape to them. Results and beamshots:
scalpel_ninja
Awesome mod!
As for the main LED, I came across a similar black plastic ring around the LED when modifying my old Novatac. When I popped the old emitter out, a small circular aluminum shim was under it, covered in thermal paste.
Perhaps some similar shims can be cut from aluminum or copper sheet with a hole punch? This way a new MCPCB can be mounted at the correct height.
hamhanded
PNW
Thanks! In this case it's just the footprint of the luxeon. The base sits flush with the aluminum. It looks similar to another luxeon that I desoldered, and under that black plastic base there was a direct thermal path.
So yes, your shim method would become necessary for whatever replaces this and would probably work just fine.
Any suggestions on emitter to replace it with? Most of the spot from stock seems to be from the dome, so it would need to be a package that has some optic built in to keep a useful amount of throw. That's the main draw of this light for me, dim flood to bright spot with just a bit more button pressure.
scalpel_ninja
That emitter sure looks similar to the one I pulled out of my Novatac. I put in a domed 519A and the beam came out really nice with the stock OP reflector. I used a 16mm copper board from MTN Electronics and hand ground it down to the needed shape. The thickness of the board put the phosphor smack dab on the same level as the stock emitter without the need for a shim.
desert.snake
Eastern Europe
This protrusion is made of aluminum. My friend modified the U2 and cut off these protrusions using an emery wheel, then a larger diode board can be installed, well, it's easier to cut. For the required height, you can use boards with a direct thermal path from Noctigon or MTN electronics and solder the same board from below to the board, but cutting off the tracks from it and sand to a flat surface, or use another source of the interlayer (copper coins example). 519A is an excellent choice for high CRI
