Knight_Light
- Joined
- Mar 2, 2013
- Messages
- 648
Re: Proposed New Armytek Wizard Pro UI:
As far as making the UI more like zebra I don't think it will happen. Zebra light has a wonderful UI but it has its shortcomings as well. There are enough consumers that are looking for alternatives and that enjoy the current Armytek UI for it to change.
You have some very unique preferences for your lights that are outside the bell curve of most consumers. I think you are justified (although I personally can't relate) in your personal preferences, to be frank with you I wish I had your preferences over mine as I would be capable of ridiculous runtimes when taking lights on expeditions without having to lug additional power sources. I honestly feel that your best bet for 100% satisfaction is just to have someone build a custom headlamp for you by modifying one of the current offerings from zebra light (if you want lightweight) or Armytek (if you want durability).
I agree with cutting the time in between levels as it would make the light seem less sluggish. Half I think would be a little bit too much, maybe around 30% would be my suggestion.can we vote this time about the UI? I would like it to be able to not only go from low to high, but back to low again, and I don't mean by just holding in the button to cycle through all other levels and modes. In a Zebralight I can double click and toggle between 2 levels. This is not possible with the Armytek. Let them change that and the lag time between levels when holding the button down. They could cut that time in half and then it wouldn't seem as sluggish when cycling through light levels.
Again I think there is enough of a consumer base that likes the .5 lm output for it to stay. Adding an additional firefly level would mean the sacrifice of one of the other levels which I think will impact negatively more people than it would satisfy. Your comment about anything over 115 lm being unnecessary would probably go against 95% of the consumer base for this particular headlamp.Also if they are considering a change in the UI, could they add a true firefly level like .05 lumen? Thrunite's original firefly level was .04 lumens and it is perfect. My biggest gripe is .5 lumens is not low enough, and I'd be happy if they made that firefly 2 with a much lower Firefly 1 level. They could ditch one of the higher modes like your proposed section 2. Cyclying through my light the 30 lumens is the highest I would ever need and anything over 115 lumens seems unnecessary to me never mind 1100 lumens. To be honest most of the 115 lumen to 1100 lumen modes don't seem all that different to me.
