An update on the Wizard Pro posted by Armytek over on cpfm.
So the current 'new' version like my Wizard pro are still v1, but with bug fixes and a couple of updates.
"The Wizard headlamps you order are only the first version at this time. All bugs are fixed and some changes are made in the temperature indication:
when it increases to +60°C, the color LED shows the warning level once a second.
After +70°C the main LED flashes 5 times. After +75°C the light output decreases to Main4 mode (550lm).
Critical level >+80°C is color indicated twice a second and light output decreases to Firefly2 mode.
The new UI will be in version 1.5 which is being prepared for production.
As I mentioned before you will be the first to know about this!"
