Are you referring to the youtube vid, if so then its possible. I am not 100% sure but it could be a 6a 20v pack yes.
My flexvolt 6a has 15x 18650 inside. The 9a and 12a both have 15x 21700 inside. Maybe Samsung 30T and 40T as examples(not opened nor plan on opening pack yet).
6a, look under the print on right side under type 1
Why pay, mmmm well why do i have lots of watches, why have 100's of torches, i am crazy like that
I simply wanted to try out the flexvolt system. Seeing what actual difference it makes to the tool also pushed me a little bit more. Yes a flexvolt on an impact driver V a 20v delwat 4a or 5a battery, the flexvolt performs better. Obviously the load across the 15 cells, larger 21700 all help reduce any voltage sag from heavy load. Testing even with 1.5 or 2a batteries V 4a or 5a again there is a difference. Especially driving in demanding screws like m12 10" types(not that i do). The smaller 1.5 and 2a packs give in pretty quick, the flexvolt just carries on. Overkill for my needs, well yes and no. I do use a lot of impact , 17,19 and 24mm mainly.
But if i also decide on some 54v tools, i have the batteries. But mainly, i just wanted in and to try the system out...........thats about it. I do have overkill running through my veins, along with better to have and not need than to need and not have:crazy:
Home wise, i wanted the 9a for chain saw use, at a pinch yes i can use on drill and impact driver to. Although i should never need to.
I already have a good few 20v batteries in work, and now a 6a flex(one of those 5a has come home now)
Home i have a 4a, 2x5a and flex 9a
