jon_slider
- Joined
- Mar 31, 2015
- Messages
- 5,183
PSA.. metal shavings..
Just received my CuTi TS10
When I turned it on it started at a low output of about 20 lumens.. after a few moments it suddenly went to Turbo. I turned it off and removed and inspected the head for any metal shavings that might have fallen between the pill and the head.
I found a large number of copper shavings, along with a rather long titanium shaving, collected in one of the grooves in the head. I could not see any shavings between the edge of the pill and the head.
I cleaned everything with alcohol, and relubricated. The problem did not reoccur
My guess is the metal shaving that caused the short was near the end of the body tubes, and it moved away from the contact ring on the pill, when I unscrewed the light. The metal shavings collected adhering to the lube in the copper head.
