Cycling light?
TheWitness33
Hello. I’m looking to pickup a light for night time gravel riding. Trails are about 8 feet wide but would like to see about 12 feet wide in front of me. And maybe 50 yards out if possible?
I have this setup on my ATV. About twice as bright as the OEM headlights.
checkout magicshine lights. or if
your feeling flush lupine in germany make very nice units (expensive)
I like using Anduril-capable lights for bike lights. There is a bicycle strobe mode I use for biking in town, or you can just use steady-on when on a trail. I have a fisblock adapter on my handlebars so I can slap a light there when needed. Typically I use a tri-or-quad-optic lights light such as the (few years old) Lumintop FW3A or the Emisar D4K, neither which have a ton of throw but enough illumination for night riding.
I put the fishblock in the right side of the handlebar so to illuminate the shoulder of the road as I ride on it, and point it slightly downward so as to not blind motorists.
Maybe worth a look in, Nitecore HC65 UHE headlamp that can be used with NITECORE BM06 headlamp bicycle bracket. I am looking at getting Nitecore HC75 UHE for the purpose of a bike light though it takes a dif battery from the previous mentioned so unable to use with bike bracket but can make something suitable.
    291.9 KB
    176 KB
    483.1 KB
    614.9 KB
    633.9 KB
    517.9 KB
  • Like
Reactions: ven
Is this a two-way trail?
I'm a HUGE fan of using a bicycle light with a reflector/cutoff at the top, so it puts all the light on the road, and doesn't blind anyone in oncoming "traffic."
In addition to not blinding someone (I don't want them to fall or - especially - careen into me), reflecting all those lumens into lux is AMAZING.
So many lights just flood the space, and I really don't need light shooting up into the sky. I need to see things on the road/trail. So, a better aimed, high lux light makes a world of difference. I realized this with one of the Ixon line of lights from Busch & Mueller from Germany. I have an older, Ixon IQ Premium that runs on 4xAA lights. It's some hilariously low lumens, but 80 lux, so it's amazing for lighting up trails (and, the reflectors keep it from blinding people WHILE increasing the throw forward, AND lighting up the sides). Those Germans, they put in some serious engineering for things. I wish my car's headlights were half as well thought out.
Then, I'll use a headlamp if I'm not on a paved trail, to watch out for branches, etc. That works better than a handlebar mounted light, because it illuminates exactly where I am looking. I prefer to use a throwy, focused beam as much as I can for this (as the handlebar mounted lights do the main illumination of the trail.
Once you use a high lux, reflector cutoff headlight, you won't ever want to waste time with the lame "flashlight, but with a handlebar mount" style lights. I'd tried some of those (I also have a machined mount by the now defunct ScoutCycling that allows me to use a picatinny Surefire scout light, haha), and they're just not my favorite. I also tried buying an Armytek mount, and using one of my right angle lights on my bike. That was...okay, but most of the light was being "wasted" blasting off into pointless directions. I just am not a fan of having a ball of floody, short range light when I'm trying to move down a trail. I want directed, focused beams like when I'm driving a car. I ALWAYS keep a spare light on my handlebars, though, so I have a Streamlight rifle light as an emergency backup, now, haha.
I have three different lights with a reflector cutoff. One by B&M, one by Nitecore, and one by Sofirn.
Sofirn has the BS01 which is still in production and you CAN swap out the battery down the road if you need to. I was impressed with that one. It was about half the price of the Nitecore or B&M, but works really well.
If I didn't already have these other lights (and the non-reflector ones), I'd probably get two of the Sofirns to run at the same time, with a headlamp, and be in heaven.
And so, I can't think of a better, nor more cost-effective solution than getting a pair of the Sofirn BS01 lights, and running two at the same time.
Tim McMahon has a good review of it, and he essentially ended up doing the EXACT same thing I did; removing the floody/throwing "traditional" flashlights, and moving to this.
Really, the BS01 is cheap enough, just give a reflector cutoff light a try. It's weird at first, but there is no going back.
Plus, EVERYONE ELSE on the trails will thank you (I've had quite a few joggers and bikers stop me and ask about my cutoff lights, because they saw just how insanely bright the trail was as I approached them, and were shocked when they weren't blinded - I've had a few people shriek in anticipation, only to be relieved, and we ended up having nice chats).
I am also looking for a headlamp to wear on my helmet while bicycling.
I am considering the Nitecore HC75 because of the white beacon mode.
Using a helmet headlamp (or daytime running light) during the day is highly recommended to improve your visibility to motorists. You should use a flashing mode during daylight, as the blinking pattern is highly effective at catching the peripheral vision of distracted drivers. [1, 2, 3, 4, 5]
Using a helmet light offers specific safety advantages, but it also comes with a few trade-offs to keep in mind:
Why use a helmet-mounted light in the daytime?
  • Catches Attention: Flashing lights are vital for daytime riding. Studies show they significantly increase your conspicuity compared to riding without lights.
  • Where You Look, Light Goes: A helmet-mounted light shines exactly where you are looking. This is excellent for making direct eye contact with drivers at intersections or looking through corners.
  • High Visibility: Your helmet is high up off the ground, placing your light closer to a car driver's eye level. [1, 2, 3, 4, 5]
Best Practices & Etiquette
  • Daytime = Flashing: Save your steady beam for nighttime riding. In the dark, steady beams allow motorists to accurately judge your distance and speed. In the daylight, a steady beam blends into the background, whereas a flashing light stands out.
  • Trail & Group Etiquette: Turn off or switch your helmet light to a low steady beam if you are riding on a multi-use path or in a group. Because a helmet light moves with your head, a bright, flashing helmet strobe can easily blind or distract other riders and pedestrians.
  • Angle it Down: Always tilt your helmet light slightly downward so it does not blind oncoming traffic. [1, 2, 3, 4, 5]
Safety Tips
  • Lumens Matter: For an effective daytime headlamp, look for a bright light with at least 300 to 600 lumens.
  • Complement Your Bike: A helmet light shouldn't be your only light. Always run a steady or flashing red tail light on the back of your bike, and ideally a steady light mounted directly to your handlebars to maintain a constant reference point for approaching drivers.
  • Legal Requirements: Depending on where you ride, helmet lights may not officially count toward legal lighting requirements (which often mandate lights mounted directly to the bicycle itself). Always check your local cycling laws. [1, 2, 3]
For more tips on choosing patterns and brightness, check out the REI Bike Light Guide. [1]
6 sites
  • Use daytime running lights on bikes for visibility - Facebook
    Oct 12, 2025 — WHY BIKE LIGHTS ARE IMPORTANT... EVEN IN DAYLIGHT By John Duggan For Active.com Washington law states: "Every bicycle when in use ...
    Facebook·E-bikes For People Over 50
  • Bike lights at night - which mode, blinking or steady? : r/torontobiking
    Jun 17, 2025 — The correct answer is steady at night, blinking during the day for both front and rear lights. The steady setting is recommended a...
    Reddit·r/torontobiking
  • Cycling Safety with Front and Rear Lights - Facebook
    May 31, 2025 — What are the most important features to look for in a front daytime running light? ... When choosing a front daytime running light...
    Facebook·NoCo Cycling
Well, I can tell you that I just bought myself a Fenix TK22 TAC for my bicycle, to replace the Fenix PD36 TAC that I was using. The PD36 TAC is now my dedicated tactical light. The beam of the TK22 TAC is much narrower, but I ride an ebike on poorly-maintained paved roads, so being able to see the potholes coming at me at 25 mph is important. For what you describe, I would think the wider beam of the PD36 TAC would work better.
Fenix just announced new bicycle lights just after I received my order, but I still think the TK22 TAC was the better choice for me.
