Dereelight DBS-T Pill Builder
holygeez03
Is there someone out there that can build me a P60 pill with modern specs for max output/throw using the DBS-T head?
Maybe with an XP-L Neutral... or whatever would work best... I can operate it with 2x18650 or 1x18650. Single cell is preferred since runtime is not a big concern, but two cell is acceptable if performance goes up perceptibly.
Even if it only operates as a single function turbo, that's fine. Neutral temp/tint with decent CRI is required.
Why you try looking on the builders & modders forum,I'm pretty certain you'll get someone there that will be able to sort what you want out.
I'll post something over there... but I'm trying to see if I can get something figured out before I go on a trip next month and I'm pretty sure someone in here can get me pointed in the right direction quickly.
