I have some questions guys :
1) I know that on the colors the upper square is the real color seen by the sun and the down one is the same color seen by the LED source (approximatively).
But what says the number underneath those ? Is it the intensity of the color seen by the LED ? What number is better ?
The top is as seen by an ideal light source of the same color. This but is important because CRI compares against the same color. It is the reason why a candle, incandescent light, and the sun are all CR100 even though they render colors quite different. The bottom number is simply the difference between the ideal and the actual. Lower number the better.
2) What are the wavelength of R9, R10, R11 and R12 ? In this case is the R12 so high because of the peak indicated by the "
1 " ?
So the wavelength of R12 is 450nm
These have nothing to do with wavelength and are just color samples the test is based around. The fact that R12 has a large error is coincidence in this case not because it has a large spike. You can end up with the same error by having too little.
