Thanks! I've browsed a bit of Toykeeper's thread over on BLF, but there's a huge amount of info to sort through there. I appreciate you condensing it down for me.
I said when you mentioned the D4 over in the SC600w IV Plus thread this light isn't really what I'm looking for. However, the more I look at it, the more it looks good enough for my main criteria, the more the interface appeals to me, and the more irresistible the price appears.
I'm not at all one to chase monster outputs, but I would make occasional use of more power (and runtime) than what my current AA lights produce, and the UI on the D4 sounds like it's versatile enough.
So now I'm debating with myself whether I want the 5000K N219C stock light, since it turns out it is available in 90 CRI, or the 4000K D4Vn. I normally prefer warmer, but there's times when I also think a high CRI daylight tint would be ideal for the situation.
FYI, the firmware is by Tom E and not Toykeeper. It is called NarsilM
True, but she did enhance it quite a bit upon Hank’s (maker of the light) request.
With the ramping UI, the max setting is up to you! Just remove your thumb from the switch. Another reason I love this UI.
Not true, these are independent branches.
TomE wrote Narsil.
Starting from that, he wrote D4 UI, with many changes for Hank.
Then he wrote NarsilM on the basis of Narsil.
So these projects were started by the same developer and they have a common ancestor. But they are not the same, UI is different, thermal control is different, D4 is 2-channel only, there are likely smaller differences too.
Indeed.I’m not denying that TomE (who’s a gifted developer) wrote Narsil and the V1 code for D4. But ToyKeeper did enhance the V1 code for D4 into V2, with for example better heat management.
My favourite EDC remains the tn4a hi, which has the best comprimise size/flood/throw in my eyes.I'm not at all one to chase monster outputs, but I would make occasional use of more power (and runtime) than what my current AA lights produce, and the UI on the D4 sounds like it's versatile enough.
I'm not sure I agree... thrunite has several single 18650 which can do 1k lumens without stress. Under 1k lumens its not that impressive... now at 4k lumens its a diff story...The way it handles heat, steps down is very impressive...........You can pretty much run it for long duration's around 600lm level(again impressive for its size).
That's exactly right. The manufacturers claim 1000 lumens for an hour or whatever but in reality the lights have to step down due to temperature issues.
Im interested by the xpl hi neutral version.
Could anyone explain me why there is so much heat and such a quick stepdown when the tn40 has the same 4xxpkhi and seems to be running a long time without stepdown.
Just because of the size ?
Btw the guys here seems to say the xpl hi is the coolest
Whats the lastest status on that ?
http://budgetlightforum.com/node/55306
