My 4-stroke equipment hasn't exhibited any (known) ill effects from ethanol fuel. The 2-stroke equipment hasten't faired as well. I've recently purchased an electric chainsaw, pole pruner, and hedge trimmer. :twothumbs
You might try a shot of starter fluid in the carb, and give it a couple of pulls. If it putts a few times, then you're getting spark, if not... then pull the plug reconnect it and hold the body of the plug against the head of the engine. In relative darkness give it a few pulls and try to SEE if there is a little spark jump the gap in the plug. If not, then the problem may not at all be your gas and carburetor.My remediation efforts on the mower a few years ago consisted of a can of 93 octane gas and a number of pulls without success. Last time I tried the chipper it would run on partial choke, which I suspect was not good for it.
I'll likely need to replace parts on both at this point.
Drygas is an alcohol-based additive used in automobiles to prevent any water in the fuel from freezing, or to restore combustive power to gasoline spoiled by water. The name Drygas is actually a registered trademarked brand name, owned by Cristy Corporation. Wikipedia
I don't know how much water it can hold but think of gas line dryer you put a small bottle of it in a vehicle gas tank and I thinking that probably makes for less than 1% concentration.I really have to wonder... how much water can 10% ethanol absorb?
We used to throw a can or two of "Dry Gas"* into our car's gas tank before winter to try to prevent water from freezing in the lines or fuel filter.
All through my childhood and into my early 20's my dad had boats. Probably from condensation in the tanks, it was not uncommon for us to get underway, and have the engine sputter for a little bit, or maybe even stall. We got really good at dropping the carburetor bowl, dumping the water overboard, and starting the engine with a shot or two... or maybe three of ether, and getting back under way.
Granted, this was before ethanol.
Agreed! Point well taken.I don't know how much water it can hold but think of gas line dryer you put a small bottle of it in a vehicle gas tank and I thinking that probably makes for less than 1% concentration.
Oh NO!!! I wouldn't touch that bet with a Twenty Dollar Bill! ;-)+
I own two Ariens snowblowers, one is from the late 70s' & another I bought new 5 years ago at a power equipment implement center.
The new one had a sticker on it saying 'use only non-ethanol gas'. Thought that was interesting because it looked like a factory sticker.
Asked the sales guy; he said it was their sticker & they started putting those on everything because all they were doing was servicing/warranting machines because of ethanol gas.
***My older Ariens has been outside my garage (under a tarp) for now five years, with the coldest of winters & hot humid summers.
Haven't started it in all that time..
I'll put $20 down that if I put a extension cord to it's electric start, prime & choke it, that it fires right up.
Battery power is way better unless your a prostitute
I am able to use 100% gasoline - no alcohol. I have stored it in polyethylene containers that were airtight for a year with no problems. I use synthetic two-stroke oil for mixes and it does well with no stabilizer for months at a time - also stored in an airtight container.
I like to run my carburetors out if I plan on storing any small engine for more than a month.
Sent from my LG-V520 using Tapatalk
Whatever additives you use, whatever type of fuel you use, please just make sure to run your equipment often enough and long enough each time to not have fuel sit too long in one place in the machine. Orbital- this is for you... This machine had sat for "a few years" and the customer couldn't get it started. (snowblower) Added fuel to dry tank, checked spark, and it popped over on starting fluid. My co-worker Walter pulled the carb off and hollered "Holy Cow!" This was the worst gummed up carb I had ever seen. I thought it was picture worthy. Walter got it running after a carb rebuild... This was allegedly regular pump gas with Stabil. I'm certain it sat for longer than a few years, and certain there was no Stabil added. Drain those float bowls, folks. :nana:
