Nice! :twothumbsBattery just died. So between 36-37 hours of runtime on the stock battery.
Just received mine. Brighter, but still a purplish hot spot. those of you who got a nice cream color won the tint lotto.
Maybe some are whiter than others, mine has some purple tint in the hotspot but not near as bad as older versions.
Mine came today. All in the 'new' blister pack as Grijon mentions. All have the ugly purple hot spot with blue and white out near the edge of the beam. New one measured 14 lumen in my sphere - one of my old ones measured 8 lumen. Definitely time for some steel wool treatment!
Hmm, if the tint is still purple I'll just stick with my good old 2008 model. Brighter purple with less runtime doesn't do anything for me. :shrug:
I would guess you have a 510GS in your version.On March 1st, 2014, I received (from Amazon)
a Blue Fenix E01, which was now carrying a 13 Lumen Rating on the box !
Definitely think you have the 510GS. I think I need to buy some more 570GS and show the comparison. Only problem for me was that the 570GS was quite floody for what I wanted but there may be some more focused ones now.Tested it, against my Previous E01 models,
and this new model was more than 1 f/stop Brighter !
( on my Sekonic L-308 DC handheld meter )
Still had that charming blueish tint, however !
:kiss:
I would REALLY like to know:
Has the electronics circuit changed ? ? ?
That definitely sound like the 510 or 570 being driven at 3.2V, which means around 50mA over the LED. If the driver is the same, then 3.2V on the old one is around 25mA over the LED and 8 lumen is about right.
Boost circuit. See http://www.candlepowerforums.com/vb...nner-s-Guide-to-explain-simple-LED-flashlight3.2V? I'm confused....please explain? 3.2 with an AA?
With an AAA even ... but as Yamabushi said, boost circuit. The E01 is unique in that is uses constant voltage, where as other lights you may know will use constant current. Most cheap lights just use a simple voltage boost so the output will not be as constant as the E01 (down to 1V). After 1V is what they used to call the moonlight mode.3.2V? I'm confused....please explain? 3.2 with an AA?
Lookin' good, Dan! I just dug out an Arc AAA, a Peak Matterhorn, a NOS E01 from four years ago, and a never carried Vihn modded one from his early days on the Marketplace. I'll start a seperate thread after opening my new ones to torture test tomorrow afternoon. Charging a camera battery, and getting out some Lithium primaries since you and Cerealand have the stock battery and Duracell alkaline runtime tests covered. :) I'm excited to be thrashing on one of these again! Four years later, hoping they are just as bombproof. We've even got snow coming in tonight and tomorrow so I can shovel with one again!!! :twothumbs
How long did it run before going into the moon mode?
run4jc,
Did you use the steel wool mod on your E01?
