coachnick
P25C Review
Fellas,
Sorry for the delay....here are my data points and opinion. Go easy on me, this is my first light and first review....of anything lol. Hope you find it useful.
Coach
Basic Stats
Low - 84 Lumens
Medium - 137 Lumens
High - 300 Lumens
Turbo - 1000 Lumens
In addition to:
-Strobe
-SOS
-Aviation Beacon
-Last mode used memory function
Power - can use CR123A(2) or 18650(1) batteries
Beam Range - 208 meters
LED - Cree XM-L2 U2
Ships with a lanyard, extra o-rings and extra tailcap
After having used it consistently for a month:
Points of Interest
-The user interface is very positive, I have medium-sized hands and can easily manipulate both the on/off switch and
power level switch. The controls are very intuitive, I was easily able to figure out how to adjust to each of the levels as well as the added features like the SOS/Strobe.
-I live on the 7th floor in my building and when on the balcony, can easily illuminate the parking lot on turbo (highest mode) -Excellent when used in the tail stand position, easily lights up the whole room. For example, I had the light in my second bedroom burn out. I needed to iron a pair of pants and it was dark out at the moment.....so with no light from outside I stood it on its tail (on a desk), put the beam on high, and was easily able to iron my pants.
-it provided a ton of light. The room I was in is about 10x12 for reference.
-The machining of the aircraft aluminium body is nicely done, comfortable, and lends itself to the user being able to make a solid purchase on the light in any position.
-the knurling is in all the right spots and does not create hot spots if held for extended periods of time.
-Small enough to fit in a pant pocket or a messenger bag (this is how I deployed it during the 'test period').
-I like the SOS feature. I have not had need to use it (hopefully never will) but I feel its a nice option to have if you ever get stranded in the middle of nowhere -just set it and let it run, giving you the ability to be seen from the air and ground at a distance.
-The hot spot bursts with intensity while the flood area surrounding it is clean and crisp with no anomalies.
Misc/positives/negatives
-No holster
-Clip is non-reversible and isn't black (would like to see it same colour as the light to add to the concealment factor if used as an EDC)
-Good solid entry level light with power/features for the money
-Could be used as an EDC light
-Would not consider it 'tactical' as the bezel is not crenulated
-Cannot reverse the clip to use on the brim of a hat
-Not sure how applicable the aviation beacon is, would like to see it replaced with something that is likely
to be used more often such as a holster or magnetic tail
-Has a momentary on for quick peeks.
-The instruction manual is nicely laid out, detailed, clear, easy to read and understand.
Notwithstanding the fact that I am a newbie, I would very much recommend this light for the average user as it is capable of tackling a variety of common, everyday tasks. Great bang for the buck!
I apologize that I did not compare the P25C to other light(s) as it is my first, and still only light, in my collection.
Fellas,
Coach
Sunwayman P 25C
Basic Stats
Low - 84 Lumens
Medium - 137 Lumens
High - 300 Lumens
Turbo - 1000 Lumens
In addition to:
-Strobe
-SOS
-Aviation Beacon
LED - Cree XM-L2 U2
Points of Interest
-No holster
