In short, yes.
HDS is very (imo excessively) conservative with LED power. I think the 219b models end up driving the LED at about 1A on max brightness. After ~30% loss between emitter output and light OTF, that gives you the 200 lumens for the higher CCTs and 180 lumens for the lower CCTs.
I would prefer if max brightness drove the 219b at 1.5A, which is a safe drive current assuming the host can draw heat away effectively. A couple of potential issues that might have informed the lower drive current:
1. HDS does not use a MCPCB for the LED.
2. There is apparently a heat-sensitive component on the driver directly under the LED. Maybe there was no other way to do it, but that seems like an obvious design problem that could limit how hard the LED is driven.
