Seriously, how am I still wearing my Winter coat just before the start of April?
Agreed, from a localized standpoint. However, the way the moon affects the tides, while small, is not negligible. Also, no matter how small the relative amount, bringing resources up from under the crust of the earth up to its surface also slows its rotation. Those are just two small factors that may compound upon each other, and that's not even including all the EM interactions our planet has with cosmic influences. I agree with you, climate change is a much larger (and longer) timeframe than weather. I'd infer that you might agree that the aforementioned factors do play integral parts in climate change, considering that they're relatively permanent and persistent...+
WAY overthought dc ^
Weather is the difference in heating & cooling, wind flows from higher pressure to lower.
..the transfer of energy is interesting, or sometimes very destructive
Coriolis effect* makes low pressure systems rotate clockwise in southern hemisphere.
Climate is factoring huge amounts of time and is much more complex.
*earth's rotation
My brain is always at full blast, which does not necessarily mean what you think it may imply. I operate like a fully regulated circuit, but function like a direct drive circuit. People often joke about me being on drugs or some other deficiency, but I've found that those people are actually just quite dumb and parrot what they've learned (including bullying), so it's not their fault.What brought this on?
Did you not get enough sleep?![]()
That grass looks pretty happyLow to mid 50s gave cause for the season's second mow.
During the end of March and all through April, mow it when the sun is shining because it's going to rain soon and might not stop for two weeks. But then, only for a day or two.![]()
Interesting that you would imply what I may think. Also that it seems everyone but yourself is dumb.My brain is always at full blast, which does not necessarily mean what you think it may imply. I operate like a fully regulated circuit, but function like a direct drive circuit. People often joke about me being on drugs or some other deficiency, but I've found that those people are actually just quite dumb and parrot what they've learned (including bullying), so it's not their fault.
Nice looking grass!Low to mid 50s gave cause for the season's second mow.
+My brain is always at full blast,
I can't believe I have to mow the lawn already...
Perhaps you could explain “those people” in your words. I try not to label people.^My exact phrasing, as quoted. The first portion is within its context, describing the operation of my brain and clarifying what it means when I say "not necessarily mean what you think it may imply, followed immediately by the description.
The next statement is a general statement, loosely referencing your statement "not enough sleep". Take it as you will, which you clearly seem to have done already. If you consider yourself as a part of "those people" that I mentioned, the statement might rub you the wrong way, then you're right. If you don't consider yourself as a part of "those people", then the statement doesn't affect you at all, then you're right. If you were once a part of those people but are no longer, then you're right.
You managed to take a moment where I share a little about myself and my observation and turn yourself into a victim and myself into a villain. Why are you doing that?
