Hi,
I am looking for a bike light.
Now I use this
http://www.fasttech.com/product/1320800-fandyfire-d99-cree-xm-l-t6-5-mode-1200-lumen-led-b
1200 lumens are not realistic for the light.:candle:
I'm looking for something better
==================Flashlight Recommendation Checklist================
____This will be mail-order or Online (location doesn't matter).
2) Budget: An easy question, but you may change your mind after answering the rest! :-)
____Up to $100.
3) Format:
____I want a headlamp with an external pack/power source.
____I want a mounted light (typically for a bicycle or vehicle)
4) Size:
____I don’t know/I don't care.
5) Emitter/Light source:
____LED (known for efficiency, longevity, and compactness)
6) Manufacturer:
____I want to buy a light from a large/traditional manufacturer that is ready to go out of the box.
____I intend to use Rechargeable cells based on less common formats (18500 or 18650 Li-Ion, RCR123, et-al).
____I want a light that has a recharging adapter (your typical "wall wart")
____I want a separate/stand-alone charger (this involves removing the batteries to charge)
____I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
____I want search and rescue type illumination (800+ lumens).
____Wide Throw: I want a beam with a noticeable hot-center for distance throw and a significant amount of "side-spill". Good for rough trail hiking, search and rescue, and general distance work.
____30-60 minutes (I have plenty of batteries just ready to be changed)
____90-120 minutes (Runtime is moderately important, but still not critical)
11) Durability/Usage: Generally the old phrase “you get what you pay for” is very accurate for flashlights.
____I want a body mounted switch (near the head, like on a Maglite).
____I want a remote switch (usually found on high-end bicycle headlights)
____I don’t know.
14)Material/Finish/Coating
____Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today’s higher end flashlights).
15) Water resistance
____IPX4 (Splash resistant)
16) Storage conditions
____In house (temperature/climate controlled environment)
many thanks
Rudy
Now I use this
____Up to $100.
3) Format:
4) Size:
6) Manufacturer:
____I don’t know.
many thanks
Rudy
