- Joined
- Apr 27, 2016
- Messages
- 398
I have a ToolTi (AAA) that hasn't gotten much use lately but today I noticed the GITD o-ring at the lens is partly pinched/partly gushing out, and appears to have sustained some damage to the part that's sticking out. Is there a way to disassemble the head so I can remove the lens and reseat the o-ring? I tried to unscrew the end but it's not cooperating. Does anyone know if there's another o-ring under the lens that actually seals against water intrusion, or is the GITD o-ring the only one in that spot? If there's a secondary seal that keeps water out then I'll just leave it as-is but if this GITD is supposed to be doing that job then that's a problem.
Thanks in advance for any help.
