M61 models over time
RWT1405
PA
So the M61 was 260 lumens around year 2020
No
In the attached picture, from the link shared, you can see the progression of the M61
08/2010 = 260 Lumens
07/2014 = 325 Lumens
02/2019 = 450 Lumens
DE73
Sweden
No
And the price has dropped from 69usd 2010 to 46usd 2023. That's quite a lot especially if you take inflation into account.
340pd
USA
I don't know how old but just dug out a spare M61 219b v2 w/225 Lumens.
Beautiful creamy tint with a hint of pink. Sounds like I am describing a glass of wine.
DE73
Sweden
Anyone know if it's safe to use an old M61 in a plastic light like Surefire G2? The M61 is from around 2010 so it's 260 lumens.
Alaskantinbender
I picked up an older M61-SHO from E bay. Interestingly enough it won't run on a single 3.7 cell but is very happy on two. Is this one of the many variations on the driver?
Kestrel
Willamette Valley, OR
My apologies for the late response, I hadn't seen your post the first time around.
I believe Gene has said that the original M61's were ok in a Nitrolon host /only if/ an aluminum head/bezel assembly was used. I'm guessing that the slight additional metal-to-metal connection on the very front helped get a little more of the heat out of there.
I do not know any guidance on the modern M61, however - and would be curious, as I'm starting to mess with a modern SST-20 M61 in a Nitrolon host. Only using a single 16650 cell, so I have should have a little bit of a safety margin. Certainly not going to do long hot runs however.
For borderline heat applications, my choice is to use 1x LiIon rather than 2x LiIon/CR123. I seem to recall Gene saying the first ~third of the orig.M61 run would be regulated on a single 18650, whereas the last two thirds would be gradually declining output. I always thought this aspect might help just enough if heat was near max.
Edit: I was curious so I emailed Malkoff; Gene said that the thermal load of the M61 should be roughly the same across its generations.
