Don,
how do you go about ordering a torch? Love the design.
I see people are still asking for a new LunaSol. Can't say I blame them. The LS20 was the first McGizmo I bought, I still have my LS27, and I modded quite a few of them to have extra brightness modes. But I know Don doesn't want to dig up the obsolete (even if still cool) PD design that the Lunasol was based on.
However, there's a different solution that could provide even better flexibility than the LunaSol design, if Don is willing to consider it: An aspheric light with an adjustable focus. It would require separate fore and aft sections of the head, both threaded to allow precise adjustment of the beam focus, and an additional O-ring outside the threads to keep water out, but those are hardly unique problems. It wouldn't be significantly longer than the Haiku either, since the space occupied by the aspheric lense would be comparable (or even somewhat less) than the space occupied by the Haiku's reflector. It would only be longer than the Haiku when the focus was adjusted to its tightest, throwiest position. And an adjustable aspheric head would be 100% compatible with the current design of McGizmo Clicky Paks.
An adjustable aspheric light combined with a multi-brightness driver would be the most flexible McGizmo ever built, even more than the LunaSol, if Don could be persuaded to offer one.
I think aspheric lights are cool. I don’t have a Haiku yet but I will some day. I’m excited for anything new Don puts out too.
Also ma tumba any chance you can share some pictures of that light?
Don already makes an aspheric light, it is called the Sundrop ;)
.... This is about a new light I personally think is pretty cool but I also think it has a small niche of potential interest. It is essentially a Mule but with a bit more focus and more attention to color rendering at the expense of flux or lumen output....
The light engine has a Nichia 083 High CRI LED as the light source and this is the significant element.
So why the name SunDrop? Well need some kind of name first and foremost. I designed a custom sapphire lens to aid in condensing the flood beam of the Nichia and the intent is to get a drop of sunlight on the target when the target can't be viewed under the sun itself. The lens itself looks like a drop and the name just seemed appropriate if not to ambitious. :o
I may be wrong but Sundrop is a spheric light, and hence optically inferior to the cheapest asphericals.
You may find adjusting the focus to be hardly ever necessary, but the perennial interest in the Lunasol design (and the Cool Fall Tri-V) shows there are people who value having a floodlight, tasklight, and spotlight all in one package. The easiest way to achieve that is with adjustable-focus optics, hence my suggestion to Don; it combines a wide range of utility with a fairly simple design that Don prefers -- simpler, even than the PD switching mechanism he used to use. LED LENSER has been making adjustable-focus lights for over a decade now, but their lights are crippled by cheap aluminum housings and even cheaper electronics. I'd be willing to learn CAD to help make an aspheric Gizmo come to life, though I suspect there are plenty of other people on CPF who already have that skill.I have a few of these (including a very high quality LensLight) but for my own personal EDC, I have found that specifically adjusting the focus is simply something I hardly ever find necessary.
That said, I probably have more lights readily at hand than most, and I typically carry an additional dedicated thrower on those occasions when that may be especially useful :)
Zoomies usually have so many artifacts and are plagued by ugly beam patterns. Having one worthy of the McGizmo moniker would be an impressive feat. The advantage in my opinion of the LS is that while it is not infinitely adjustable the beams are actually pretty good in both configurations vs. a zoomie with an ugly beam in nearly all positions.
I made a lens based zoom early on and it worked pretty well but definitely loss as you pulled the lens away from the LED getting towards a collimated or focused image but with more and more light bouncing around inside and probably not getting out of the head. I think there was much less light loss with a reflector based zoom design I played with. I think if one had a good heat pipe and pedestal mounted LED you could have the option of a Mule with reflector dropped down and then a good collimated beam with pulling the reflector forward for image focus. In transition I would guess it would suck with artifacts prevalent. I wonder though if Mag would dust off their beam focus patent and claim infringement.In addition, a lot of overall output is lost using an aspheric conifguration especially when defocussed if I understand correctly.
