I have something special in mind for this particular configuration and am holding out until its ready, which should be next month. :sssh:
I'm guessing Fire and Ice versions, too cool!
Very interesting. Thanks for sharing that valuable insight, Maxbelg.
Hi Tom!
Your PM inbox is full. I'd like to send you a PM please.
Thanks!
I've been thinking of getting one of these for some time now.
Just looking for some feedback from current users and Oveready before buying. I've tried emailing through the Oveready site but never hear back from them.
- I've currently have a Nailbender P60 XM-L2 T6 @3.6a with a smooth reflector in a cryos bezel. I definitely like it but more is better right? Am I going to say "Wow!" when I turn the M2DD on for the first time?
- Just wondering how it compares to the XM-L P60 format in general. A lot more throw due to the reflector depth, tighter hot spot, etc.
- I see in the description, it says "mounted on solid copper base". Does that truly mean a direct mounted LED or is it on a sinkpad board?
- The description says it exceeds the current rating of the McClicky switch but yet another page states "We guarantee our kit up to 5 amps, more than double the factory Z59 rating. Note: amps over 3 will heat the spring!" Seems contradictory. For those of you using McClicky switches, how are they holding up? I don't want a zero rez as I like the click switch.
Thanks!
Ok. This light is SICK!!! I don't have a hound dog XML anymore, but this light is every bit as potent if not a lil more, in a smaller package. Like a hound pup. Lol.
Just got one of these heads for my bored C2, light output is simply incredible! Significantly out throws my XML2 Nailbender P60 Drop in.
So I finally got the chance to play with the M2 xml2 and it is definitely a winner!
The throw on this thing is about the best I've seen for such a compact light using an xml2. I would say the throw is equivalent to the G5 but, of course, with a much wider coverage. This is actually pretty amazing if you consider that the depth of both reflectors are about the same, but significantly wider on the G5 and uses a much smaller led.
I noticed the Grey Turbohead's non-ribbed page has been gone for a while,will there be anymore?
how many more batches of these do you think you will come out with before Christmas? everytime I see a batch come and go I fell like I just screwed myself.
We've run low on a key part, slowing production. However, one last batch of full lights are on their way for Insider 45 and more heads in both colors should be ready by December.
Do you have any plans to do a run in gloss black?
I would like a HA 6P host to go with one of the remaining heads. rather its custom HA black, natural, or even a fire 6P body and tail matched with a black head. im just not a fan of C2's for some reason.I would love to, our first batches were all gloss black. But M2 bezels are effectively discontinued. We have no reserve of gloss back, no way to to buy them, and no way to to make (refinish) them.
We can make hosts that match the heads we do have. Would you have a preference?
