Modified Mini Christmas Lights LED set
Wolf Lonesome
Toronto, ON
Hi guys!
I just recently modified a 50 LED lights string by replacing the original small LED lamps plus resistors
which have been soldered to the positive leads.
I put 50 10 mm slow colour changing RGB LED's, adding of course resistors as well.
The problem is both the light # 1 and # 25 does NOT lit at all, the rest is just working fine.
I've checked the fuses (inside the plug) and the rest of LED's - it is fine.
I know this is a two parallel circuit connected in series.
When I remove a # 1 LED, the whole string goes out.
I count a LED number one and number 25 starting from the plug.
So the #1 and #25 are not burned simply does NOT lit.
Any suggestion would be really helpful for me.
