wedlpine
Olight has another new light. The Olight M18 Maverick.
http://www.olightworld.com/en/products_show.aspx?ProId=1857&CateId=389
It's too bad that it can't be used with a 18650.
7.Highly efficiency constant current drive circuit, perfectly support CR123A, RCR123 or 18650 batteries;
If you look at this pic, it doesn't say it supports a 18650.
If you look at the spec list itself it says that it can be used with a 18650. Confusing :P
That table is messed up. It looks like they mixed up Modes 1 and 2. The pic shows mode 1 running for 2 hours at 500 lumens and mode for 9 hours at 1000 lumens.If you look at this pic, it doesn't say it supports a 18650.If you look at the spec list itself it says that it can be used with a 18650. Confusing :P![]()
1000 Lumens?? I see 100 lumens. :PLooks like the upgraded version of the S20 with a tailcap button. Same thing they already did with the S10. That table is messed up. It looks like they mixed up Modes 1 and 2. The pic shows mode 1 running for 2 hours at 500 lumens and mode for 9 hours at 1000 lumens.
lol oops! Must need more sleep1000 Lumens?? I see 100 lumens. :P
Most leds used in flashlights are rated at 50.000 hours. Of course this is a rating and failures may occur.I have just ordered a Olight M18 Maverick, I would like to ask, does anyone know what the LED is rated for in hours?
