Does anyone know how many grams the light weighs without batteries? Thank you.
just thought of this, but if I got a de-domed option, wouldn't there be a big tint mix due to the inherent de-doming tint shift? I wouldn't want a ton of mixed tones
From the site, looks like 366g
A few questions:
1) The flashlight head's positive battery contacts of all 4 batteries are one gold contact for all batteries. Doesn't this cause problems for batteries with slightly different voltages and discharge currents?
2) What is the parasitic drain for this light?
3) Are the individual LEDs easily replaceable? With 12 LEDs, one may go bad and it would be nice to know it can be easily replaced.
4) Is the white-colored body HAIII? Is the white coat as thick and protective as the grey coat?
From what I've read:
1) Most multi-18650 flashlights have the cells in parallel just like this light.
12.9 oz; 366 grams - which makes this light heavier than the MM15. But as RMM noted, this is probably due to the heavier copper heatsinks/plates. All in all, the M43 should weigh 19 ounces with 4 batteries inside.
Thanks!:welcome:
