Schokokeks
So, I got some LiFePO4 CR2 cells for a rangefinder, but I do not have a single charger that fits these.
I DO have some dummy CR123A cells (just the wire inside) as well as a Malkoff dummy (Brass center rod surrounded by plastic).
Would it be safe to charge these using the dummy cells to make them long enough to fit into the charger?
I know you DO NOT CHARGE A BARE DUMMY CELL, but if it can safely discharge through the dummy, I can't see why it couldn't safely charge through one.
I'd be running this at a low power, anyway, cause these are just a few hundred mAh.
