Dioni
:faint:
nice collection :twothumbs.....versus the LR2 straight away, what's the advantage here, more tailcap options? did you have to do anything else to make the 2aa work? & did those rings come with your body?
I prefer the L2P over the regular L2 more due to it's less agressive bezel styling and tailcap design than the coating.Is the HA III coating on the L2p worth the increase over the standard L2? Have people noticed the coating wearing better than the standard L2?
The Solarforce drop-ins do have memory.Also, do the 3-mode dropins that are offered with the L2's have memory
Hmm, I didn't realize there was a difference in the designs of the L2 vs. L2p. Is there a post in this thread that shows the differences?I prefer the L2P over the regular L2 more due to it's less agressive bezel styling and tailcap design than the coating.
If Solarforce made the L2P style tailcap and bezel rings available for the regular L2's, I'd be perfectly happy with buying a regular L2 with those instead.
As for the coating wearing off, I haven't had that happen to me.
I accidently dropped my L2P sortly after I got it :ohgeez: and it took a chunk out of the bezel ring.
14 x CR123a (1500mAh nom.) giving ~42V would be 21,000mAh
14 x 16340 (750mAh nom.) giving ~50V would be 10,500mAh
7x 18650 (2600mAh nom.) with ~26V would be 18,200mAh
Working out how to run anything off the above is left as an exercise for the reader.
You can't add the capacity for batteries series.
Norm
Yep.Hmm, I didn't realize there was a difference in the designs of the L2 vs. L2p. Is there a post in this thread that shows the differences?
Thanks. The crenelation on the l2p is slightly less pronounced, the knurling looks less aggressive, and the tailcap doesn't protrude as much. Is this it? I like the protruding tailcap b/c it's easier to activate.
In the grand scheme of things, yes, that's it.Thanks. The crenelation on the l2p is slightly less pronounced, the knurling looks less aggressive, and the tailcap doesn't protrude as much. Is this it?
Both the L2p and L2 with aggressive bezel block output , way to much .. Look good butt , that all important output , the recessed retaining ring offers the highest output , and Im thinking of putting one on the L2p .. Ive already tested it with the recessed retaining ring and I like the output gain .
With my L2p - XP-G R5 pill - 320 with bezel - 380 without ..
Thats with original bezel and with bezel removed ...
With aggressive L2 bezel , 320 ...
with flat SS bezel - 360
If ever I get that lathe , I will make some low profile lens rings that hopefully allow closer to full potential .
I use the 26.8mm x 1.85mm UCL lenses from flashlightlens in all of my L2s.And as long as we are on the subject, what lenses have you found that allow more lumens to pass through and where can we find those? Thanks.
By aggressive do you mean the super long Klingon looking thing or the standard L2 crenelated bezel?With my L2p - XP-G R5 pill - 320 with bezel - 380 without ..
