SkyRC MC3000: How to start another program on a finished slot without disconnecting the battery?
Volta
Guradorf
Hi,
I did not find this informations at the internet and not in the manual, which may be caused by me being not a English speaker.
I want to know, how can I choose another program for a slot, which has finished a program (LED=green) without diconnect
the inserted batterie first?
Best regards,
Volta
sbj
Keep the SNB button pressed for 2 seconds - the finished program flashes - press the SNB button briefly - the last program number appears - use the up or down arrow to select a new program - to start: keep the SNB button pressed for 2 seconds
Volta
Guradorf
Thank you! :) Is there a way to stop al slots with one button when all slots are green?
sbj
What else do you want to stop?
When all charging slot LEDs are green, all processes are complete. :)
There is no off switch. If there were one, you would have to remove all the batteries before switching off. There is a risk that the batteries would otherwise discharge slowly. caution.gif
