think2x
is this a modded light?
M6LT head on an M4 body I think.
Hold head neck flats toward lens side in vise with wood jaw protectors. Insert pipe or solid into battery compartment so the body does not crush then wrap body in leather then use a large pliers or pipe wrench to turn.
The light Surefire should make.
900 single mode clicky dual 17670 or primaries.
New aquasitions
L60 and SW02 :)
The L60 still needs to be bored out to finish my shortie :)
Just curious, but does that Oveready tail cap make the tail cap a twisty only? no momentary or click?
Maybe wrap the batteries with a piece of paper or tape them together... I would think that any kind of a plastic washer would keep it from making contact when tightened, but I have never used one.
One thing to keep in mind that we learned back when the first z57 tailcaps were not working to well. There is a plastic washer under the wrapper on the negative side of your cr123 batteries.
Mines not set up properly yet though and I can't find any info from other people how they have set theirs up:(
When switched off/ untwisted the battery rattles because there is a gap. My only idea was a fibre washer or a plastic spring but I'm not sure weather it would work and I can't find the parts I need to try it :(
The ZRS adds 15 mm. I have an Oveready TL20 body with a 18350. You can do a TL34 with a 18500 or a TL50 with a 18650 (or 2x18350). Oveready puts o-rings at the top to help with rattle. A lot depends on the spring of the dropin. A longer spring will give you more play. You can also use a spacer (TL50, ZRS, spacer and either a 16340, 18350).
Is the rattle from diameter or length? To stop rattle from diameter, you can wrap the cell in light cardboard. To stop rattle from lenght, you can use an o-ring or lengthen the spring from the dropin. I don't have these issues with my set ups that use the ZRS and I find them very robust and reliable. Another random thought - are you unscrewing the tail too much? Also, see the Oveready site (>Upgrades, >Body Upgrades) for the Battery Bumpers.
