Surefire Lego?
All surefire and malkoff parts.
Can someone explain the body/battery configurations of these?. Thanks.
I'll give it a go and if if miss something someone else chime in to correct me.
Top to bottom and head to tail.
Top light: (3x123 size but likely running 2xAA?) KX2C, body from a 2 cell Malkoff forend light, Surefire A21, A19, Z41
Middle light:(2x123) Surefire EB2 head, 2 cell Malkoff forend body, A21, Malkoff Tail cap
Bottom light:(1x123) Malkoff 1 cell forend light, A21, Z49
Haven't seen these combinations on here yet . . .
These were built using the head from an M600P Fury Scout Light which works fine on E-series lights. Cosmetically it's not a perfect fit as the head tapers down narrower than the outer edge of the E-series body but that has no affect on function.
Something a little bit different :thumbsup:
I finally finished IMO my Ultimate SF LEGO and Battery Vampire.
Here are the goodies.
-Malkoff M31LL
-Yellow Nitrolon G2 head
-Yellow Nitrolon G2 tail fitted with a McClicky
-LU60
-A21
-Slightly Modded AN14 in yellow
-17mm to 14mm delrin sleeve for 1xAA epoxied into AN14 to isolate the ITP adapter from internals.
-ITP Ti A3 body with tail post and threads filed off. Also internal neg spring shortened (not required)
Using A21 and 1xcr123 power.
Using AN14 and 1xAA power.
Showing an AA beside the ITP adapter with AAA in it.
And finally, using the AN14, ITP adapter and 1xAAA power
