Ha. Yes. I went with both. Might as wellBoth [emoji4]
So, as I mentioned before, the tactician head works well on a LX2 body. With the head tight you get a nice useful low. Id say 25 lumens. If you want less of a low, loosen the head and you get roughly 5 lumens or so. Small package as well.
Did you have to heat the head?I was playing around with my Tactician and found that my BOSS head wrenches fit the Tactician head...
I replaced the flat gasket with a more traditional o-ring because when I tightened everything down the gasket would bunch up and not sit flat.![]()
Nope, the head wrenches made it pretty easy.Did you have to heat the head?
Thanks for the comparison picture. I think the EDCL2-T length is a bit exaggerated because of the unscrewed tailcap? (looks like that).
Is that the old school semi gloss black model or the flat black model? Thanks.I'm back the the original pocket clip, the 2 way is just a little too flimsy. Also if anyone wants to ditch the lanyard loop check out the twisty tailcaps from Lumens Factory [emoji106]![]()
Not sure, didn't know lumens factory made different models.Is that the old school semi gloss black model or the flat black model? Thanks.
Yeah, they make 4 different ones. 2 clicky and two twisty(both available in matte or semi gloss black).Not sure, didn't know lumens factory made different models.
Are they shipping again ?
