- Joined
- May 4, 2014
- Messages
- 720
Its hard to see anything in that pic but, if you are talking about in between the different pieces of the head, it could be the thread locker/silicone SF uses to seal their heads. Also, after a little research, I see that some of those joints use flat rubber gaskets as apposed to o-rings(in addition to the thread locker/silicone). So, if a bit of the gasket is showing it very likely is still sealed and makes no difference. Honestly, either way I would just use it man and utilize the lifetime warranty if needed.
I'm talking about between the different pieces of the head, might be the thread locker or a flat gasket, now i at least have it documented and seeing as how having it serviced from Sweden is a rather huge pain in the nethers if it's something that could save me a lot of effort in the long run with some clarification on their end.
