Configure the turbo timer
Enter config menu by 8 (or more) fast taps, wait for the blinking signal, then enter turbo config mode by the according number of taps (see mode list). The light then runs at full power. Let it run for the desired time (e.g. until it gets hot; use a full battery), then tap to switch off. That time is now set for the turbo timer. Setting a time below 4 seconds disables it. The turbo timer has a maximum of ~20 minutes (this is also the default). It applies to all modes above 50% and smoothly ramps them down to 50%.
Think its 30 quick presses from menu, once its on just let it run, when you think its hot enough switch off and its set for that time.
Can't seem to get into turbo timer mode. After 30 quick press it does nothing. If I press and hold the button, it lights up. If I let go it turns off. Removing tail cap returns to normal and back to last group that I set it to.
Hello VNaholics! :grin2: I've recently registered to these forums but I have lurked here for a while. I found out about Vinh lights here and read a lot of good things about them so I decided to take the plunge! Ordered a S200C2vn. And I guess I got lucky, because my first light was a Fiat Lux! I'm hooked! Lol
I wonder if anyone else has had this experience?
I have 2 separate vn lights on order, and both have been shipped. Both were set to arrive within 1-3 days. I am in New Mexico, so it should be a fairly-straight shot from western Washington, right?
My first package, inexplicably, went from Washington to South Carolina and is now enroute and should be here by Monday. Maybe. I confirmed that the shipping address is correct, and of course the helpful postal employee had no idea why the package was routed in this manner.
The second package was shipped immediately, but the tracking scan has not been updated and I won't know until Monday if it is coming via a more direct route or if it is traveling the country like the first one.
There is a reason why, in my household, USPS stands for "United States Piece of Stool" and has for quite some time.
Vinh, have you ever considered an "upgraded" shipping option (via UPS or FedEx)? I, for one, would be willing to pay for this service.
Tough call which really you can only answer tbh drummer, me i cant say anything other then the q70 as i picked that over the others.............
Shaved dome, if its 14,000 or 14,500 etc, you would not be able to tell easy by the eye if at all imho............At that level its crazy bright!
Go with what you would use the most, that would be my advise, all would be amazing in their own way.
What use do you have in mind?
