I love Zebralights and over the years have owned a bunch. I have had some QA problems with my Zebralights, but perhaps this isn't surprising as I tend to get first-run preorders. Over the years I have had the following:
[TABLE="class: grid, width: 500"]
[TR]
[TD]Light[/TD]
[TD]What I liked[/TD]
[TD]What I didn't[/TD]
[/TR]
[TR]
[TD]SC51[/TD]
[TD]my first Zebralight. Great size and nice UI. My first quality e-switch light.
[/TD]
[TD]Super slippery body, easy to accidentally turn-on button, and greenish tint. Clip mount gets in the way after "clipectomy" performed.[/TD]
[/TR]
[TR]
[TD]SC52[/TD]
[TD]even smaller than SC51. Much better button with much less chance of accidental activation.
[/TD]
[TD]Greenish tint. Slippery body. Clip mount gets in the way after "clipectomy" performed.[/TD]
[/TR]
[TR]
[TD]SC80[/TD]
[TD]Finally a small Zebralight with grip![/TD]
[TD]Seemed a bit bigger and heavier than needed for the size battery used though. Also my light had a QA issue where H2 didn't work. All other modes worked fine except H2 (light would blink and then turn off if cycled to H2).[/TD]
[/TR]
[TR]
[TD]SC52w[/TD]
[TD]Just like the SC52, but with neutral yellowish tint.[/TD]
[TD]QA issue: Mine tended not to stay in 500 lumen turbo more than 30 seconds though even on a fresh 14500.[/TD]
[/TR]
[TR]
[TD]SC600[/TD]
[TD]Great light. Nice grip in hand[/TD]
[TD]Too large for pocket EDC. Greenish tint. My early preorder had a QA issue with a defective switch. Was fixed via warranty repair.[/TD]
[/TR]
[TR]
[TD]SC62w[/TD]
[TD]nice output and perfect tint with no hint of green. Nice size.[/TD]
[TD]Slippery body. QA issue in that wouldn't stay in turbo for more than 5 seconds. Returned for replacement which mostly fixed the problem, but still doesn't stay in turbo as long as it is supposed to.[/TD]
[/TR]
[TR]
[TD]SC32w[/TD]
[TD]Perfect tint. Much better tint than my SC52w.[/TD]
[TD]Light is almost too small. QA issue: Same problem as my SC62w... won't stay in turbo more than 15 seconds even on a fresh quality 16340. As a result, I consider this light too unreliable to EDC.[/TD]
[/TR]
[TR]
[TD]SC5w
[/TD]
[TD]Great grip. Great tint.
[/TD]
[TD]Heavy with a thicker than needed battery tube. No 14500 support. Serious QA issue: After 1 month of use, max output declined from 500 lumens to approximately 25 lumens. All modes continue to work, just turbo is now around 25 lumens making this light useless for EDC until repaired.
[/TD]
[/TR]
[TR]
[TD]SC63w[/TD]
[TD]nice size, perfect tint, no QA issues.
[/TD]
[TD]Super-slippery body in need of knurling. Ramps down relatively fast due to heat. Clip mount gets in the way when clip is removed (problem common to all Zebras with the screw-in clip)[/TD]
[/TR]
[TR]
[TD]SC600w III HI[/TD]
[TD]Perfect in every way and my favorite Zebralight. Feels like a million bucks in the hand, small enough to EDC, great throw, perfect tint, zero QA issues, can run in turbo mode indefinitely. Very little ramp-down due to heat even when left tailstanding on turbo.[/TD]
[TD]Lanyard ring digs into the bottom of the hand. However, this is forgivable as the ring also serves as an antri-roll device.[/TD]
[/TR]
[/TABLE]
