Your use of states indicates US origin? if so, you can refer to your states lighting codes and look for some by-line along the lines of "promulgates regulation in accordance with cfr49 subsection 108," which will tell you that your state has incorporated the federal lighting regulations by reference. In laymens terms, if federally legal, it's good to go (probably).
Cutting to Cfr49, subsection 108, you'll find a color reference chart which tells you what is federally defined as "white" light. You'll see it's a pretty broad chunk of space, very similar to the charts used in LED binning and labeling documents to discuss variations in the tints available. Those further up and to the right in "white" led's will be considered white light sources, and you can get very warm color temperatures indeed.
You'll note there *is* a distinct gap between very warm white light, and what is considered "yellow" under federal law. But very warm white LEDs, especially if higher CRI should accomplish what you're looking for, even though they are less efficient than their cold white counterparts. LEDs have come a long, long way in the last 20 years, the least efficient high cri and warm color temp LEDs are still multiple times as efficient as the first several generations of high output white LEDs.
Here's a link to cfr49ss108, you'll need to scroll (and scroll and scroll) down to the reference tables section near the end of the page to find the chromaticity diagram
www.ecfr.gov
And here is a link to the diagram itself, hosted as an image (poor quality at that, but usable).
