In an effort to expand the scale of Newbie's testing, I will be sending him some mismatched cells.
Newbie has shown that if you partially drain a cell and couple it in series with a new cell, venting can occur. We have been using the ZTS tester to match cells, but the question keeps coming up "Will ZTS mismatched new cells vent in the same way as when you physically mismatch cells?"
I will be sending Newbie cells that tested at 60%, 40%, 20%, 10%, and one cell that came in at 0%. Along with these cells will be those that tested at 100% to pair up with the mismatched cells.
All of these cells are brand new and have never been used. They are Titanium cells that came from the stock that Wayne pulled off the shelves when he discovered that he had a bad batch of cells back in April. I did some testing on the cells demonstrating what parameters the ZTS tester was looking at, and decided that they may be able to assist us in understanding what is going on with the venting of cells.
Wayne took some cells from this batch back to the factory, along with a ZTS tester and a SureFire M6, to demonstrate the problem to them. As I recall, the result was that while the factory does a test similar to the ZTS test, they were using different resistor values. I believe these values were adjusted to subject the cells to a higher load. I have heard that Wayne has been continuing to do random checks of the new cells he has been receiving, including ZTS testing, and has been pleased with the results.
Since this batch of cells has some known issues, it is my hope that we can get some meaningful information from them.
Newbie asked me if the testing of these cells could be delayed until he got his data logging device functional. I left the decision up to him. We are all interested in the ability of the ZTS tester to add to the safety of using multi-celled lights, but we also have to keep in mind that this is a destructive test with a limited amount of samples. Also, keep in mind that no testing like this has been done, so we don't know how the results will play out.
It is my hope that this will not be a total waste of Newbie's time and efforts...
Tom
