soffiler said:
NewBie: for the sake of clarity... these are both brand-new cells? (as opposed to you depleting one purposely down to 10%)
If they're both brand-new, I'd suggest this was more a ZTS tester anomaly than a real mismatch test. Which also helps explain why the "10%" cell pulled ahead of the "100%" cell, and why there was no venting.
Yes both are new, just tested on the ZTS tester by Silverfox, and put into the test rig.
Okay, here is a run that was done identically to the last one:
I took one of SilverFox's 10% cells, and put it in a glass of water that was at 59C for 10 minutes, and I am doing a run with that right now as I type this, to see how it affects the results.
Here are the results from a ZTS tested 10% cell that was preheated to 60C, inside a ziplock bag, for 10 minutes, paired up with a ZTS tested 100% cell. Notice how the plots changed...:
Now compare the venting plot (pay attention, the time scales are different):
It looks alot more like the venting plot now. I'll be doing a longer preheat next, about 30 minutes, so that the heat can get into the center of the cell a bit better. This heating has a very vague simularity to the heating that occurs in a performance flashlight, especially the PM6. Besides the head section of a PM6 heating up very nicely inside, it also has a very heavy guage spring, which helps to conduct the heat to the first battery.
I have a few more tests I'd like to try, then I'll get a PM6 rigged up for the test, and we can see how things go there.
